Old 01-31-2021, 05:17 AM
Scarbrough Scarbrough is offline
Default 8" Deburring Wheels??
I have a DeWalt 8" Bench Grinder and was wondering if anyone has ever mounted a 6" Scotch Brite Wheel to an 8" Grinder. Mine has the 5/8 Hole and I cannot seem to find them anywhere. Any help or advice would be appreciated.
Old 01-31-2021, 05:29 AM
mturnerb mturnerb is offline
They make bushings/adapters to fit the shafts for standard bench grinders.
What I ended up using for deburring was one fine 6" wheel and and one medium 6" wheel mounted to a Harbor Freight buffer on a stand.
Buffer:
https://www.harborfreight.com/6-in-b...q=bench+buffer
stand: https://www.harborfreight.com/univer...tand-3184.html)
Advantages include easy access to wheel with longer shafts on each side. The medium wheel removes material quickly - very nice when you fabricate a part a little big and need to remove material to get it to size.
Parts like this I always cut with extra material and use the wheels to shape to size and deburr:
I got the HF idea from Synergy Air's class where they had it set up in their shop.
Long answer to a simple question but of all the tools in my shop this one got used the most and saved me a lot of time and aggravation.
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 01-31-2021, 06:16 AM
Default Scotch Brite Wheel
Thank you for the quick reply! I like the setup I'll have to seriously entertain this purchase.
Old 03-06-2021, 06:57 AM
lonkelm lonkelm is offline
The wheels used are Scotchbrite? The fine and medium wheels?
Buffer:
Old 03-06-2021, 08:47 AM
BillL BillL is online now
Yes, not included - sourced separately. You will need to do some research on the actual 3M part nomenclature as words like red, brown, tan, fine, medium will not be helpful to find the desired wheels.
The two 6" wheels offered by Cleaveland are representative what you might want. I have these two on a HF buffer - the cheaper one. The 7A (medium) wears like steel - it will polish a file easily.
https://www.cleavelandtool.com/produ...polish-wheel-6
To the OP question: Here is the catalogue for 3M, they do list some 8" wheels.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
