  #11
Old 09-16-2021, 12:47 AM
Jake14 Jake14 is offline
Originally Posted by fr0gpil0t View Post
I didn't think you were meant to put sealant on the threads of flare fittings ? But I'm a new builder.
Heís correct. Sealant should only be applied to the NPT portion of fittings and nothing on the side that gets a B nut for aluminum line or hose end.
I don't see where the OP says he used any sealant
RV-14A flying 520 hrs
Old 09-16-2021, 05:24 AM
PaulvS's Avatar
PaulvS PaulvS is offline
I (also) assumed that the black substance that is visible on the threads in the photo is sealant, it sure looks like it, but I'm not certain exactly what it is. I've learned a bit from these posts, so it has been helpful.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 09-16-2021, 08:04 AM
rvbuilder2002's Avatar
He didnít, but if you zoom in on the photo you an clearly see what looks to be Permatex #2 under the B nuts.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-16-2021, 09:17 AM
I'm alittle late to the party, but we've used the Military/Commercial aviation guidelines. Seemed logical to me that if its good enough for military, why question it.
Tom
Click image for larger version
Name:	Tube Flare details.jpg
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 09-16-2021, 09:20 AM
Originally Posted by TS Flightlines View Post
why question it.
I don't see that anyone has Tom, unless you happen to know that the OP has lines made by you......
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-16-2021, 10:12 AM
painless painless is offline
Agree on the flair size. Another fix is to use the real thin aluminum flaired inserts that are available for the various AN sizes. They take up any discrepancies in seating the fitting to the tube flair.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 09-16-2021, 10:19 AM
I agree that the Dell seals are a good option when a good seal can't be made with the standard connection.
Generally, the tubing we use on RV's is soft enough though, that if the flaring is made properly and the connection is properly torqued, a leak is rather rare.
Where the Dell seals are of a lot more value is in hard connections. Such as hose end connections. Particularly when it is a hose with a steel sealing face interfacing to a steel AN fitting.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-16-2021, 10:27 AM
walldan's Avatar
walldan walldan is offline
Tom
What book is that? Can you give me the title? I would like to get a copy.
DW
Mechanical Engineer
Student Pilot
RV-9/14- Collecting Tools
Volunteer Firefighter/EMT
Old 09-16-2021, 10:51 AM
JDeanda JDeanda is offline
Default Small Thing
Iíve flared a few tubes, aluminum, stainless and even copper. Sometimes, if a new flare leaks, it just needs to be loosened and retightened a time or two.
Old 09-16-2021, 11:17 AM
Ron B. Ron B. is offline
I tip I was given on here as to flaring alum tube is to apply a drop of oil on the tip of the mandrel before inserting it into the tubing. Made a huge difference for me in quality flares.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
