Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-16-2022, 03:11 PM
W728 Reinforcing Strip at Wing Tip with platenuts?
I am about to finish the removable wingtip preparation. What is the consensus on the W-728 reinforcing strip if installing platenuts for a removable tip?
Drawing 17A shows a W-728 reinforcing strip on the inside of the wingtip flange to receive either permanently installed rivets, or rivets from platenuts on removable wingtips. The verbage on page 7-13 says the reinforcing strip is not necessary with platenuts and the removable tips.
Do I believe the words (no reinforcing strip) or the drawings (reinforcing strip either way)?
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2022
"...serenity...courage...and wisdom..."
11-16-2022, 03:33 PM
I did not use the strip on two RVs with anchornuts.
No issues.
Did us soft rivets on #2 to help prevent crushing the glass.
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Flying. Titan IOX-370/ CS/G3X
N184P reserved (RV-8QB) Empennage kit and QB wings in the shop
11-16-2022, 03:41 PM
I rivet the nutplates to the reinforcement strip, than rivet the strip to the fiberglass flange between every second or third nut plate.
Worked fine for me, but any of the three methods would be fine.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
11-16-2022, 03:44 PM
Nutplates
The nutplates are pretty solid, but a strip would certainly help. It's easy to install a thin strip bonded with G-Flex.
I found it works for me to bond reinforcement strips before drilling for nutplates or countersinking for rivets.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
11-16-2022, 07:06 PM
I did the strip install with A rivets which worked well for me. The AD'S rivets are prone to crack thin fiberglass in my experience.
11-16-2022, 07:29 PM
I used a strip on the -6. Rethought it and just riveted the nut plates directly to the tips on the -10. I don’t think the strip is necessary - it’s just extra work and weight.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
11-17-2022, 04:47 AM
No issues.
Same here - and I used floating nutplates - worked fine.
11-18-2022, 01:32 PM
anyone have the issue where the wingtip sets about a 1/4 further aft then the aileron does?
11-18-2022, 01:39 PM
Happens all the time. A straightedge and a cutoff wheel will make quick work of it.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
11-18-2022, 02:57 PM
Thank you for the info
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
