w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 03-11-2023, 02:10 PM
plehrke's Avatar
plehrke plehrke is online now
I ordered a 6 non prepunched power coated and i got it yesterday. I will definitely use solid rivets. Drilling out the skin rivets is easy and only takes a minute. Even easier to re-rivet the skin with the squeezer.
Philip
RV-6A - flying 1000+ hours
Donated to VAF yearly since 2007. Why? Because it is worth every penny and more.
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. —MARK TWAIN
Old 03-11-2023, 03:05 PM
megerj megerj is offline
Default Access to accomplish SB-00036
Not a builder...patience please. Also I tried, really...to find a thread about opening another access point to evaluate SB-00036 (rear outboard elevator hinge bracket area on rear spar).
Question - Can you drill out a new hole closer to the mid point for easier access than the current tooling hole? If yes...any engineering analysis and directed location?
Meegs
RV-8
Old 03-11-2023, 04:58 PM
bhester's Avatar
bhester bhester is offline
Default This is all I can say!
Mine!
Click image for larger version
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2022 VAF donator - a lot better than any magazine subscription
Old 03-11-2023, 06:01 PM
greghughespdx's Avatar
Yes. Referenced in Step 1 in the service bulletin and Figure 15 on the last page. Describes the options to enlarge the existing tooling hole, but you can also add another hole if needed for inspection in the outboard rib. Just be sure to put it the new hole on the centerline and leave sufficient material from an edge-distance perspective when choosing where to drill on the centerline.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Last edited by greghughespdx : 03-11-2023 at 09:51 PM. Reason: Clarified how to add a second hole if needed
Old 03-11-2023, 08:49 PM
rvsxer rvsxer is offline
Originally Posted by Webb View Post
Parts arrived in mail today. I’ve already primed and will let the primer cure for a few days unless I put the parts on top of the heater and bake them.
Not to ignite a new primer war but what primer did you use?
Mike Hilger
RV-6 N207AM w/G3X, 2000 hours
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 03-11-2023, 10:21 PM
Webb's Avatar
Webb Webb is offline
SEM Self Etching
Webb Willmott
Jackson, MS
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
Old 03-12-2023, 08:17 AM
Glen P Glen P is offline
What's the method for ordering a kit? An email to support or some other method?
Glen Palmer
Toronto, Canada
RV7 C-GCPM (first flight April 28, 2022)
Dues paid August 2022
Old 03-12-2023, 08:23 AM
Dad's RV-10 Dad's RV-10 is offline
Originally Posted by greghughespdx View Post
New kits are available on the Van's online store for the following kits (each link below will display the kits for that model(s). NOTE that we are currently shipping ONLY the non-powder-coated brackets (you will prime with a self-etching primer of your choice). If you order a powder-coated kit, we will not ship a kit to you until the parts are available, and we do not yet know when that will be. If you need to repair an airplane now, order the non-powder-coated kit.
Old 03-12-2023, 05:42 PM
SEM Self Etching
Thanks, Webb!
Mike Hilger
Old 03-12-2023, 05:55 PM
Webb's Avatar
One side done. Time was 2 hours. Not a big deal. Solid rivets installed. Should take about an hour on other side due to learning curve.
Helpful notes for others:
- Remove rivets on the top or bottom skin all the way to the middle rib and front spar to allow room to get hand in. I used a #42 drill and drill stop. Rivets came out with no damage to skins.
- Brackets were easy to remove. Use a #40 and drill all the way thru the rivet.
- Break the rivet tail/head off.
- Use a punch and lightly tap the rivet out. If stuck, use a #30 drill and drill a smidge out and re-punch. All came out and the holes in the spar all looked good.
- After buggering up 2 heads trying to squeeze and drilling out, the rivet gun was superior to the pneumatic squeezer due to clearance.
With 32 cherry max rivets for later use, the kit was a great bargain.
ID:	39578  Click image for larger version
ID:	39579  Click image for larger version
Webb Willmott
Jackson, MS
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
