w/a Donation
VAF on Twitter:
@VansAirForceNet
  #41
Old 09-13-2022, 09:20 PM
Scott Hersha Scott Hersha is offline
Maybe I’m lucky (because I know I’m not good), but it’s never taken me more than 15 minutes to check/inflate my tires through the 1” opening in the aft wheel pant, covered by a snap cover. No need to remove the forward wheel pant. I use a piece of rubber flexible hose to capture and remove/reinstall the valve cover cap, and my extension shader valve easily bridges the gap. I carry spare parts of these items in my fly away kit.
SH
RV6/2001 built 2000/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/August 2022 build - Flying
Cincinnati, OH/KHAO
DEC2022
Old 09-14-2022, 03:59 PM
Erimo's Avatar
Erimo Erimo is offline
I made a hole in each wheel fairing, which I plug with a metal clip. A white mark on the tire allows the valve to be positioned opposite the hole in the fairing.
All I need is a rigid valve extension and a piece of semi-flexible tubing.
The tube is used to unscrew the valve cap.
I need two minutes by tire.
Click image for larger version
ID:	30970  Click image for larger version
ID:	30971  Click image for larger version
ID:	30972  Click image for larger version
ID:	30973  Click image for larger version
Eric
RV 14A - #140252 - Flying
France
2021 Dues Paid
Old 09-14-2022, 04:56 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Originally Posted by gasman View Post
I have a spot marked on the floor for each tire. I just roll it into place and the stems line right up with the 1" access holes.....
I bet that works - exactly once.
And then randomly after the first time.
Like another poster above, if you don't have marks on the tires, you will get very good at reaching in and feeling for the stem between pushes. It is sometimes possible on a very level floor with no flat-spot set in the tires to move the plane by pushing on the pant or grabbing the leading edge while under there, until you feel the stem touch your finger.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 80 hours
66 years running stock DNA
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Default Easy, fast, uncomplicated
Exactly! Maybe even 10 minutes to do both. I have the tire/wheel marked so I know where the valve is and it is nothing to roll the airplane so it is lined up. Easy. Fast. Uncomplicated...
Michael
RV-4 2860 SuzieQ
1946 C-90-8 J-3 Cub
The adventure begins when things stop going as planned - Glen Heggstad
Exempt but still a happy Subscriber! 2022-2023
Old 09-14-2022, 05:12 PM
robert@jonesrv10.net robert@jonesrv10.net is offline
I hate the small access holes so I put automotive Bluetooth pressure sending units on all 3 tubes. Now I only take the front half of the pant off to inflate the tires when necessary, which isn’t often since I buy the no leak tubes.
Robert Jones
Las Vegas, NV
RV10 N810K
Old 12-29-2022, 09:08 AM
HFS HFS is offline
Default 6" Inflator Valve Extension - Offer & Pricing
Not here to debate the + & - of adding air to main gear tires w/o removing the WP. Only that I do it, and am offering the following (until I run out - 8) inflator valve extensions @ my cost + shipping (~ $5.00). I am also including the P/N's and vendors where I obtained my parts - total unit cost <$10.00.
1. Tire Chuck, Brass/Steel. Vendor: Zoro P/N G2143127 or Grainger P/N 1KUH2
Both under $5.00
2. 6" x 1/8 NPT Brass Pipe Nipple. Amazon P/N LTWFITTING Brass Pipe 6" Long
Nipple Fitting 1/8 Male NPT (Pack of 5). Unit cost: $3.85
3. 1/4 Male x 1/8 Female Bushing Adapter. McMaster-Carr P/N 4638K351.
Unit cost: $.98
I turned off the "flats" on the body of the Tre Chuck to give a little better "streamline" for putting it into the hole (whatever size you have) in the WP.
I am giving away my time for the lathe work & assembly. If anybody wants one for the materials cost + shipping - call it $15.00, just PM me and we can work out the details. I only made 8, but the vendor list & P/N's should be enough to get started.
I put mine on a flex hose, pistol grip style inflator & like it for the ease and convenience. I do have another inflator that has a lever style "trigger" with the sliding pressure scale, which has the extension rigidly attached to the body of the inflator - I don't like it as well as the "flex" unit, but that's just me. To each his own.
YMMV - But this does work!
HFS
Name:	EZ-FLATE - Inflator .jpg
ID:	35877  Click image for larger version
Name:	EZ-FLATE - CU.jpg
Old 12-29-2022, 11:20 AM
GOFT GOFT is offline
Default 7500 "Hi Jack"
Eric, what metal ring did you install around the tow-bar hole?
An elegant way to protect the paint and fibreglass.
RV-14A Flying Jul 2020, thanks to all on the forum.
Donated 2022. Keep up the good work Doug.
Old 12-29-2022, 12:26 PM
HFS HFS is offline
Default FlyBoy Accessories - Tug Guard for Nose WP
FlyBoy Accessories sells this product -
Name:	Tug Guard for Nose WP.jpg
Old 12-29-2022, 07:34 PM
Default Tug hole
Thanks. Looks quality, but pricey. Might be able to lathe something similar.
Old 03-19-2023, 05:57 AM
Biggiesauls Biggiesauls is offline
Default Tug ring
I used these as tug ring hole protectors… from Amazon
https://www.google.com/url?sa=t&rct=...pZQ_H-8pgDyoGc
Greg Saulsbury
RV-9A builder since Covid 2020
95% done, 5% left to go!
Tail - done
Wings - done
Fuselage - done
Avionics - done
FWF - 95%, working the punch list…
https://eaabuilderslog.org?s=gsaulsbury
2021 Dues Paid
