w/a Donation
VAF on Twitter:
@VansAirForceNet
  #2061
Old 11-06-2022, 11:38 PM
Mnemonics's Avatar
Mnemonics Mnemonics is offline
Looks great Larry
Marcel Heijmans
RV-7 PH-MNX
Blog ph-mnx.nl
Vlog YouTube: PH-MNX
Builder# 74668
Member NVAV
Old 11-09-2022, 09:08 AM
ryankhallcpa@yahoo.com ryankhallcpa@yahoo.com is offline
Default CMI SIL011
Brian, sorry for my late response.
I've attached a Continental Motors Service Information Letter (SIL) 011. An internal oil passage needed to be tapped and plugged.
See section VI: Conversion to Constant Speed
Ryan
Name:	CMI SIL011.pdf
Taylor, AZ (KTYL)
Builder #74649; RV7 N789YZ;
XIO-360-M1B built by JB Aircraft Engines
My flight bag is made by Dewalt!
Old 12-13-2022, 10:04 PM
griffg griffg is offline
Default First engine start
Check out the video below which shows my son and I doing the engine start for the first time. It fired up first go and ran very good.
https://flic.kr/ps/3TnTEo
We have since taxied it around the airport and also calibrated the magnetometer in the Advance Flight ADAHRS.
Gordon Griffin
RV-7A - beginning test flying
VH-NAK
IO-360-M1B
Catto 3 blade prop
Old 12-14-2022, 12:49 AM
gregmc gregmc is offline
Woo hoo, go Gordon!!
Greg
RV-7A
Fuselage in progress
Empennage and wings done-ish
Old 12-20-2022, 10:01 AM
motodave motodave is offline
25 hours in Phase 1 and still grinning! Flying great with no trim required after wheel pants and leg fairings:
Untitled by Dave Hock, on Flickr
Looking pretty :-) it's been cold in CO. Was not expected much heat from the standard heat muff and happy to report that it puts out a TON of heat. I've been flying with it just cracked a small amount with a very pleasant cockpit with the OAT's below freezing.
Dave
RV7 Slider N732DH
YIO-360-EXP Thunderbolt
Garmin G3X panel w/VPX
Littleton, CO & KCFO (aka CO Air and Space Port)
Photo log: https://flic.kr/ps/9jjZz
Old 12-21-2022, 10:59 AM
kentlik's Avatar
kentlik kentlik is offline
Dave,
Such fantastic work and still so impressed by your craftsmanship!
Very inspiring Sir!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 01-11-2023, 08:03 PM
Default First flight
On Monday VH-NAK took to the sky for the first time with Glenn Bridgland at the controls. Glenn is a Flight safety Advisor (FSA) with the SAAA. I took advice that the builder should not do the first flight and Glenn has many hours on RV's.
Check out the photo below for the RV grins, especially on one happy old builder
https://flic.kr/p/2ob53Go
Then watch the video below. After I took it I realised that I probably should have zoomed in.
https://flic.kr/p/2ob4PRR
The aircraft flew well but I do have a heavy left wing that needs correction.
Gordon Griffin
VH-NAK
IO-360-M1B
Catto 3 blade prop
Old 01-11-2023, 08:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Congratulations
Big, big congratulations!
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 01-11-2023, 08:29 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Originally Posted by Vfr1200 View Post
Starting on the canopy , God help me please
Schedule warm weather to do this!
Richard
VAF# 835 N755RC
RV-7A /FWF/Glued canopy/Wings Attached! AW CERT!
Slow build --- ALL THE WAY
Victim of LYCOMING SB-632-B
2023 Dues Happily Paid
Old 01-12-2023, 04:23 AM
Congratulations Gordon, that's fantastic!!!
Greg
RV-7A
