VAF on Twitter:
@VansAirForceNet
Old 02-04-2022, 07:09 PM
Flandy10 Flandy10 is offline
Default Rv10TDI returned to flight
After a VERY LONG year, the task of changing out the prototype TD300 diesel engine for the type certificated SR305 engine is complete.
The factory sent a representative to inspect the installation on Monday and finally on Tuesday…
It came to life…. https://youtu.be/6iXa01u8nqo
First flight was Wednesday…
https://youtu.be/IUJRRmyfz3w
Short first flight-yes. Several other flights were made after making prop and governor adjustments. An alternative engine mapping was also tested.
More testing to come…
Scott Flandermeyer
Rv-10 TDI 380 hrs
Fayettevile, GA
2022 VAF Donation complete
Old 02-04-2022, 08:02 PM
majuro15's Avatar
majuro15 majuro15 is offline
Scott, congrats on the flight and your patience! Good to see it’s back flying. I’m excited to hear about more details.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
CRJ/PC-12 Pilot
N1017H RV-10 Flying 2019
EAA Lifetime Member 1106970
2022 VAF Dues Paid!
Old 02-05-2022, 07:31 AM
Scott----PROUD OF YOU---not only for the work, but the persistence to see this through. WE wer pleased to have been a part of this project!
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 02-05-2022, 08:53 AM
KiloWhiskey1's Avatar
KiloWhiskey1 KiloWhiskey1 is offline
Congratulations Scott! Sounds great!!
Keith Ward
Current: RV-10 N253RV, RV-3 N235RV,
Sold: RV-7 N818PA, RV-7 N818KW, RV-8 N626JL, Christen Eagle II N56RJ
Old 02-05-2022, 08:55 AM
rocketman1988 rocketman1988 is online now
Default following!
Can't wait for more updates!
I noted that there are a couple of versions of the SR305; are you using the 230 hp or the 260 hp?
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
In Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2022,...Thanks DR+
Old 02-05-2022, 01:11 PM
A2022 A2022 is offline
wow. a lot of work. it seems it could be worth it for the future, but I guess it depends on how much you fly.
Old 02-06-2022, 10:00 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Congrats Scott, looking forward to more specs as you fly the new engine.
I'm confused with the nomenclature describing this engine. It's been called so many different things over the years. Have they settled on something finally?
You mention re-mapping. Is this version now FADEC controlled or does it still maintain the mechanical injection it had previously?
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 460.7 hrs. on the Hobbs,
RV10 95% built- Sold 2016
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 02-06-2022, 10:07 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Well done, Scott, can't wait to see performance numbers.
Scroll
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 02-06-2022, 01:05 PM
This is the 230HP SMAAE SR305-230E. The TD-300 prototype was returned to CMI.
I am thankful to my friends at CMI for the chance to start this project. Covid/economy/changes to the production engine/etc. were slowing progress toward the completion of our agreement, a type certificated production engine. 2020 saw SAFRAN sell the SMA line of engines to the Roder Group in Germany (SMA Aero Engines)and I saw an opportunity. Like CMI, they see the potential in the airframe/engine combination that I do. So I switched manufacturers and as I promised with the TD-300, I will provide data once I have the installation adjusted- both the good and bad. Which hopefully won’t be too long.
The MAIN difference between the SR305 and the CD-265/TD-300 is the SR305 has a computer that controls the ground and flight idles, along with max power. It is not a FADEC system,like the CD-155 or Austral 300 on the Twinstar, as there is a mechanical back-up mode. SMA licensed/sold the SR305-1 information to CMI to produce their engine as they saw fit, hence the visible similarity between the two.
Scott Flandermeyer
Rv-10 TDI 380 hrs
Fayettevile, GA
Old 02-09-2022, 12:05 PM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Very interesting for sure. Can't wait to read more about it. Besides the specs and performance numbers that everyone wants to know, I'd especially be interested in what's all involved in converting a flying RV-10 with a 540 to this diesel.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
