Old 03-03-2021, 04:26 AM
Bear Creek Skunkworks Bear Creek Skunkworks is offline
Default Backfire
Had the same thing happen to a customers airplane, RV14, when an Emag went 180 degrees out of time. Not only did it require replacement of the air filter it blew a 3 inch section out of the tailpipe. Very expensive to repair. No answer as to why this occurred.
Terry Gardner
EAA Technical Counselor
A&P IA
Light Sport Repairman, Airplane, Glider, Powered Parachute, Weight Shift
CTO
Old 03-03-2021, 05:44 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, as stated, this was most likely caused from an earlier backfire. We see a few of these very year. Somehow it gets missed on the preflight. I seriously doubt it could happen in flight without a lot of damage elsewhere.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-03-2021, 07:35 AM
Champ's Avatar
Champ Champ is offline
Good point on the snorkel. I’ll check it today.
Dennis Enns
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags, OW Award Oshkosh 2017
2021 Donation In
Old 03-03-2021, 09:30 AM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
Originally Posted by Champ View Post
I had a dirty injector, cleaned it and did another GAMI Lean test using Savvy's procedure. The lean test came out good with .4 GPH spread. However at the end of the 3rd run I also did an in-flight mag check. I was aggressively leaned at this point and heard what I thought was a cylinder missing on both the Left & Right mags (a little worse on the Right).
On my walk around today I saw this on my intake filter.
Attachment 8967
It looks more like a backfire than a cylinder miss. Is it possible to get a backfire in a situation like this?
I'll be ordering a new filter K&N 33-2060.
Mine looked similar after about 500 hours. The metal mesh deteriorates over time and changes into the shape/position that the filter is oh slightly loaded to.
Old 03-06-2021, 01:06 PM
Champ's Avatar
Took the cowl off - no damage or evidence of backfire in the snorkel. Pulled the air filter - damage to the pleats and breaks in the wire mesh. No bulge like Scott's picture. So, could be either backfire or weakened filter stressed mechanically like Kevin suggested.
New filter is on order from ACS.
Click image for larger version
Name:	Filter Topside.jpg
ID:	9081  Click image for larger version
Name:	Filter Underside.jpg
Dennis Enns
2021 Donation In
