VAF on Twitter:
@VansAirForceNet
  #11
Old 01-21-2023, 07:21 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Correct... I have Michelin AirStop tubes that have very low leakage rate. Very rare if I have to inflate tires during summer season. Michelin AS tubes are incredibly expensive...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 01-21-2023, 08:06 PM
seagull seagull is offline
I have the Michelin tubes also. Every 60 days I check pressure and typically add 2psi. I do a visual tire check every time I walk up to the plane. The only reason I can see the remote sensors useful is on a landing checklist. Any leak is going to create a visually flat tire so the wheel pant is coming off regardless. I use the 1” hole and a screw on extension, very quick to add and check. I use witness paint to mark the bottom of the tire when the valve stem is aligned with the 1” hole.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
Old 01-22-2023, 07:57 AM
maxmirot maxmirot is offline
Originally Posted by maxmirot View Post
I have these on my main tires and they work perfectly.
Did you put one on the nose gear tire ?
I did'nt.
I can't unscrew it and add air without removing the front pant
Max
Has anyone put a sensor on nose gear?
Can you take it off and add air with removing the wheel pant?
Old 01-22-2023, 01:52 PM
Piper J3's Avatar
Nose wheel uses same long 90 degree valve stem as used on main wheels. There is not enough clearance to the fork for a TPM. I tried....
Old 01-22-2023, 11:11 PM
RFSchaller RFSchaller is offline
I ditched my wheel pants after a couple of years. It was too much hassle to add air. If the tire goes flat the weight goes on to the wheel pants and you have to jack up the plane to fill the tire. They look great, but not really practical.
Old 01-23-2023, 06:34 AM
Webb's Avatar
Webb Webb is offline
Default Cessna did it
I’m surprised that something like the oil filler door hasn’t been done more often like Cessna’s had. Seems easy enough to do.
Click image for larger version
ID:	37244  Click image for larger version
ID:	37245  Click image for larger version
Webb Willmott
Jackson, MS
RV8 - Current Build
V35B - Flying
RV7A - N32WW (Sold)
Old 01-23-2023, 06:47 AM
Webb's Avatar
Right about here.
Webb Willmott
Jackson, MS
RV8 - Current Build
V35B - Flying
RV7A - N32WW (Sold)
Old 01-23-2023, 07:22 AM
Piper J3's Avatar
Cessna can't even make pilot / passenger ingress doors so they stay shut....
Old 01-23-2023, 07:29 AM
Mel's Avatar
Mel Mel is offline
Reminds me of an ad I once saw; "When one door closes, another one opens. Other than that, it's pretty good Cessna."
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-23-2023, 04:53 PM
Handclutch Handclutch is offline
Default Re ditching wheel pants
I did a trip last year to some remote parts of Australia where facilities are very limited. I removed the main gear pants to make it easier to deal with a flat but left the nose gear in place.
Having seen many reports of pants being worth 3-5 knots, I was expecting a slower trip but there was really no change. Perhaps the nose gear accounts for most of the drag?
Jack
