Go Back   VAF Forums > Model Specific > RV-9/9A
  #31
Old 04-05-2021, 02:23 PM
M5fly's Avatar
M5fly M5fly is offline
Default Getting ready for the fun...
Resurrecting this thread... I recently found some play in the nose gear on my 6A and decided to go with the tapered pin repair. I just ordered the parts and they should be here later this week. Hoping to get it done the following weekend.
My question is what is the easiest/fastest way to do this on a flying aircraft? My initial thoughts were to unhook all necessary hoses, mounts, wires, etc. then hook an engine hoist up, unbolt the engine mount from the firewall, and move the assembly far enough forward to access the hole and complete the job from underneath. Does this sound reasonable or am I going to need to remove the mount from the engine and clamp it to something in order to get enough force on it while drilling/reaming?
I was hoping the entire job could be accomplished in one long day, but maybe I'm crazy... It seems like a lot of folks have gone this route during their builds but I haven't been able to find a ton of info on the best way to accomplish this on a flying aircraft.
If only this could be done from the top without removing the engine or mount!
Cole Melby
N642RV at KCXP
1992 RV-6A, O-320 150hp
Bought flying, 1/2021
Exemption waived, 2022 donation made
Old 04-05-2021, 04:28 PM
cajunwings cajunwings is offline
Default Nose gear taper pin
Done this on a 6A & 9A. Donít see how it could be done without removing the engine. Might be possible to do this job on a long day with some good help and no snags. Both times I left the prop & baffles installed and only disconnected things that were necessary to free the engine.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Click image for larger version
Old 04-06-2021, 05:48 PM
M5fly's Avatar
Don Broussard
57 Pacer
Would you recommend removing the engine first and then the mount or can it be done by freeing the mount from the firewall just enough to allow room to complete the job?
Cole Melby
N642RV at KCXP
Old 04-06-2021, 09:21 PM
gasman gasman is online now
Cole, you may save yourself a lot of work if you try a longer bolt first. The stock bolt measures under size right near the threads. This causes the mount to have only one fitted surface and that is near the head of the bolt. This will cause play in the gear to show up.
Replace the stock bolt (20A) with a 21A. Going by memory, I think I installed one washer under the head of the bolt, and two under the nut..... This procedure takes about 30 minutes and may solve your problem.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 04-07-2021, 06:54 AM
Walt's Avatar
Walt Walt is offline
The NAS6605 series also run a few thousands larger.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 04-07-2021, 09:04 AM
Both times I left the mount in place on the firewall and reamed from the top down. It took a lot of inward pressure on the reamer to get it to cut. If you wanted to ream from the bottom up I think the mount needs to be off the engine.
Don Broussard
57 Pacer
Old 04-07-2021, 11:34 AM
M5fly's Avatar
Do you happen to have the specs so I get the right one from ACS? I already ordered the taper pin but if this easier fix works I can always return the other stuff. Is this a bolt I could find at Fastenal or only from ACS? My only fear is this fix will be good for awhile but I might have to do the taper pin option down the road as it wears more... I may order the NAS6605 as well and see which works best. I have the same question for Walt on which NAS6605 series part number is correct.
Cole Melby
N642RV at KCXP
Old 04-07-2021, 11:50 AM
M5fly's Avatar
Don Broussard
57 Pacer
How were you able to torque the nut reaming from the top down? I'd prefer that route but didn't think it was possible.
Cole Melby
N642RV at KCXP
Old 04-07-2021, 08:15 PM
Default Taper pin
On the 6A there was enough room. On the 9A I used the end of a wooden broom handle to form a small rounded dent/depression in the stainless firewall at the nut location. The material is pretty soft so easy does it. Didn’t take much, maybe 1/4 the size of a golf ball. I seem to remember having to cut the tip off the reamer so it wouldn’t contact the firewall.
Don B
Old 04-07-2021, 09:15 PM
I ordered five AN5-21A bolts and measured all of them for the best fit. You need to add at least one washer under the head for a good shank fit, and two under the nut. The nut used was MS21045-5. The washers AN960-516.
The bolt went in from the top with the washer, and you add washers and the nut as the bolt is exposed out the bottom or you will not get the nut on.
When ready to torque, measure the drag of the bolt, the tighten the nut to the point of needing the torque wrench and add the drag torque to the bolt torque spec.
