Keep VAF
Going
03-25-2021, 09:20 PM
Close Quarters Riveting
What's the best tool you recommend for dimpling/riveting tight areas close to spars? I had a pin hole puncture in my trim tab and was advised by Vans to drill to #40, dimple and set a #3 flush rivet. After I drilled the hole and deburred, I realized that I'm too close to the spar web to be able to dimple/rivet. I'm looking to expand my tools anyways. What do you recommend? Unfortunately, it's also somewhat beneath the trim tab horns, so only about 1/4" clearance on top and about 7/8" clearance on the bottom.
Building RV-9A - Empenage Kit 99% complete, wings QB received and started
03-25-2021, 09:29 PM
Pop rivet dimpler with the female die ground to a “D” shape to get in close to the spar.
If you haven’t ground some dimple dies, well, you will....
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Final stages. Titan IOX-370
N184P reserved (RV-8QB) Empennage
03-25-2021, 10:35 PM
diy
Make your own close quarter dimple dies from mild steel and use a machine countersink to make the depression. The male part of the die is a matching rivet that will be tapped into the hole with a drift punch. The dimple won't be perfect, but it will be good enough in such a location.
The rivet itself can be set with a squeezer or a narrow flush set and thin bucking bar.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
03-27-2021, 11:14 AM
Thanks Paul. Your feedback has been very helpful.
03-27-2021, 11:23 AM
Dimple tool
My first choice for something like that is a Cleveland Vice Grip Dimpler.
Second is the pop rivet dimple tool
Third is a 3/16" gun set. The dies fit in the set. Turn pressure down to about 10 psi and feather the trigger. I also have home made bar that holds the female.
Fourth is a home made close quarter jig as mentioned above
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
03-27-2021, 11:32 AM
That's a tight spot.
I think I would forgo putting a rivet in there. Use a debur tool to put a little more of an angle on the hole, then mix up some epoxy with milled fibers and fill the hole; push the material into the hole - forming a sort of mushroom plug.
Sand & Paint...
Brian Decker
RV-7 (Flying)
03-27-2021, 03:58 PM
Use an NAS1097-3 rivet. You can countersink with a couple turns of your deburring tool. Set it with a no-hole yoke in a squeezer or a long set in a gun.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
03-28-2021, 09:23 AM
Not to go off-topic, but "close quarters riveting" reminds me of installing a transponder and encoder in my first plane - a 150.
A&P: "I need you to crawl back in the tail cone and buck these rivets."
Me: "OK"
HOLY ****!
Bowling Green, KY. all paid up!
03-29-2021, 08:31 AM
I'd use a pop rivet and fill in the hole.
But, if you decide to try riveting a solid rivet, use a soft rivet.
It would be a rivet without the divot in the middle of the rivet head and much easier to squeeze. (AN426A rivets)
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder currently flying
RV3B & Legend Cub
03-29-2021, 11:05 AM
+1
Pop rivet all day. There are a few spots where I wish I had simply used a pop rivet and called it "good enough" instead of trying to be "better" with a solid rivet.
Eric G.
Ann Arbor, MI
RV-9A under construction (QB fuse)
President, EAA Chapter 333 Flying Stinkers
Thread Tools |
Display Modes |
