Old 05-12-2021, 06:09 PM
seagull seagull is offline
Originally Posted by seagull View Post
I am wondering if the calculation for fuel use will change. More pressure should mean more volume. We have only one flow sensor reading the total fuel pumped.
I flew 2 hours today. Checked the tank fuel level with my dip stick before and after flight. The Dynon was exactly accurate on fuel remaining. I did not change the k-factor after the new higher pressure pump.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 05-12-2021, 06:31 PM
jrock836's Avatar
jrock836 jrock836 is offline
Originally Posted by piperpilot View Post
Does anyone know the difference between 40106 (not 105) and 40135? The original is 40105 (lower pressure) and both the 105's and 106's are stock at aircraft spruce but not 40135's.
Here is the tech info on all of them, very close in detail and appears 106 and 135 are the same specs.
https://www.facet-purolator.com/tech-information/
Maybe the connector on the positive lead?
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
LSRI-A for N49DD / EAA / AOPA
Pvt Pilot since '79! / USNR - MA2
Retired LEO / PADI MSDT / SDI OW Instructor
Scuba Equipment Tech (PT Retirement Job)
“If you can walk away from a landing, it’s a good landing. If you can use the aircraft the next day, it’s an outstanding landing.” – Chuck Yeager
DONATED
Old 05-12-2021, 10:00 PM
The 135 comes with the “packard” connector which is a male spade connector in an odd plastic housing. I had to cut it off and add a female spade to match up with the plane harness. It looks like the 106 doesn’t have a connector, just bare stripped wire.
-- Walt --
Old 05-13-2021, 07:13 AM
piperpilot's Avatar
piperpilot piperpilot is offline
Thanks for the replies, this is exactly what I saw from the specs. Basically easier to crimp on a new connector to a bare wire on the 40106 to connect to the filter capacitor and power supply lead.
Unfortunately Notice N18-07-12 specifies 40135 only, despite several Facet pumps with the same specs and dimensions. It also seems the 40106 is stock in many more places then 40135, at least here in Canada.
Thanks all.
RV12 C-GWSE
Old 05-13-2021, 07:19 AM
piperpilot's Avatar
...I also love that Facet/Purolator posts "NOT INTENDED FOR AIRCRAFT USE" on every webpage and document...
"WARNING: FACET AND PUROLATOR FUEL PUMPS SHOULD NOT BE USED IN AIRCRAFT AS THEY ARE NOT DESIGNED, TESTED OR MANUFACTURED FOR ANY AIRCRAFT APPLICATIONS." ...but they work perfectly for me.
RV12 C-GWSE
Old 05-13-2021, 09:28 AM
jrock836's Avatar
For something like an extra buck, Van's includes the appropriate connector to match up with the "Packard" connector.. Either way, I guess you either cut the plane's wiring harness, or the connector on the fuel pump.. Potato - Potatoe..
Joe
DONATED
Old 05-13-2021, 10:01 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Potato - Potatoe..
I didn't know Danny Quayle owned a RV-12...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 685
Old 05-13-2021, 10:23 AM
jrock836's Avatar
Haha... I bet way more than half here have no idea what you're talking about..
Joe
DONATED
