Old 04-18-2021, 05:55 PM
PilotjohnS PilotjohnS is offline
Originally Posted by wirejock View Post
I get the alternator current limiter.
What is on the inside on the main bus? Breakers, VPX or Aircraft Control Module?
Just curious. I plan to use the ACM.
here is my schematic. FYI.
The ANL protects the alt wiring and also the wiring going thru the firewall to the fuse block. Dont want smoking wires aft of the firewall.
Name:	schematic desktop.jpg
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 04-18-2021, 06:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Stuff
Thanks John
Ok folks. Cough it up.
What else don't I need that I don't know? No wait.
What else do I need that I know? No wait.
What else... Oh bother!
Just give me the scoop please.
Feel like I'm sucking a Sweet Cream Malt through a cracked straw.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-18-2021, 09:44 PM
jcarne's Avatar
jcarne jcarne is offline
Mine are both 60A fuses for the reasons mentioned above. Many argue they aren't needed because the wire will arc any shorts with the firewall until the metal is gone and no more arcing. Ummmm... I'm not comfortable with that. Hence I used two of them. One for alternator and one for the main line into the cockpit. You will want to do a search on this topic as there are many different ways a guy can hook it all up especially when you throw a shunt into the mix. The Dynon manual shows the different ways the shunt can be positioned.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 04-20-2021, 08:57 AM
wirejock's Avatar
Default Brass bar
Vans plns show a brass bar between the two contactors. I can't find it on my inventory or parts.
Is it a local hardware store item?
Is it permissible to use a bar to connect to the ANL and or Shunt?
Larry Larson
Estes Park, CO
Disclaimer
Old 04-20-2021, 09:16 AM
jcarne's Avatar
This is what you need.
https://www.aircraftspruce.com/catal...?clickkey=4696
Jereme Carne
PPL
Old 04-20-2021, 09:34 AM
jjb jjb is offline
Default Copper
I am using a VPX-Pro and elected not to use a shunt per Vertical Power installation options.
But here is what I did. The ANL's are for main and standby B&C alternators.
I used .125 copper sheet obtained economically from the usual big online vendors (not ACS, although that will certainly work) and fabricated what is in the picture.
jb
RV-7
QB Fuse in progress
Wings and tail done
Old 04-20-2021, 10:11 AM
wirejock's Avatar
Default Copper
Copper. Sorry. I knew. Just typed the wrong metal.
Very neat!
Exactly what I planned. Thanks for the confirmation.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-21-2021, 10:05 AM
amaris amaris is offline
Buy some extra length too. I didn't like the fit of my first attempt so redid it.
Allen Maris - 2020 Dues paid
7A - 544RV In Progress
Santa Ynez, CA
Old 04-21-2021, 10:27 AM
wirejock's Avatar
Default Copper
I never get anything right the first time except mistakes.
I fabricated a scrap aluminum bar and ordered two 12" pieces!
Larry Larson
Estes Park, CO
Disclaimer
Old 04-21-2021, 10:32 AM
jcarne's Avatar
I agree, buy two 12 inch pieces just in case. Keeps shipping down too.
Jereme Carne
PPL
