VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > RV-6/6A
Old 07-06-2022, 05:13 PM
jask jask is offline
Default Antisplat ball bearing wheels
I spent the day Tues with Allan getting the wheel bearings installed. I have not installed the main wheels yet but the nose wheel spins extremely easy. I did the balance myself with a modified HF motorcycle balancer. This will do a lot to prevent the nose wheel from locking up and folding the gear. Pressure on the nose gear will not increase bearing preload as it does on the tapered bearings.
I am extremely pleased with his workmanship.
RV-7 builder Ramona, CA.
Free prop balancing for Van’s owners.
RV-6A N665CM
Old 07-06-2022, 06:16 PM
erich weaver's Avatar
Can’t remember ever hearing about this happening before
Erich
RV-7A
Santa Ynez, CA
Old 07-06-2022, 07:06 PM
Default nose wheel
The design of the nose wheel system is not good. There is a 3/8 bolt that has two jobs. It serves as the axle and also adjusts the preload of the bearings. If enough pressure is placed on the nose wheel, the axle will bend and increase the preload on the tapered bearings. If the pressure is great enough, the bearings will lock up and the nose gear folds. IMO, it is the main cause of nose gear failures.
RV-6A N665CM
Old 07-06-2022, 07:45 PM
Roy Thoma's Avatar
Roy Thoma Roy Thoma is offline
Default Poor nose wheel axel design
I agree that the nose wheel axel in RV's with the Matco wheel is poorly designed. Anti Splat bearings is one way to improve the design and minimize the rolling resistance.
I think the lease expensive way to reduce the rolling resistance of the nose wheel is the axel assembly from Matco. See http://www.matcomfg.com/AXLEASSEMBLY...dv-3657-1.html
Another way to minimize the rolling resistance, and to get rid of the tube that we use in a tubeless tire is to get the Beringer nose wheel. Aircraft Spruce is one source. See https://www.aircraftspruce.com/catal...oaAsSWEALw_wcB
I flew with the Matco wheel and axel for about 10 years before changing to the Beringer wheel.
On Soapbox: I've seen a handful of nose wheel flats using the cheap Van's tube in the tubeless type tire. My plane and sever others. It's my belief that tubes should not be used in tubeless tires and that doing so contribures to the tubes failing. The inside of the tire is rubbed away - because it is not designed to have a tube against it. Cord is exposed against the tube and it destroy's the tube. Off Soapbox.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 2000hrs as of 6/5/22:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 2012 25' Eddie Bauer Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
Old 07-06-2022, 09:21 PM
Default Axle
I was not aware that Matco offered that axle. It solves the problem but you still have to pack bearings.
RV-6A N665CM
Old 07-06-2022, 09:27 PM
Walt's Avatar
Walt Walt is offline
Grove also offers a tubeless wheel with an improved axle design.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 07-06-2022, 09:33 PM
Default Axle
Does the set screw mess up the threads on the Matco axle?
RV-6A N665CM
Old 07-07-2022, 08:05 AM
lr172 lr172 is offline
+1
Thousands of RV's with the std bearing. SImply NO WAY a tight bearing will cause a nose gear leg to fold over.
Larry
Old 07-07-2022, 08:15 AM
BillL's Avatar
BillL BillL is online now
A low rolling resistance will allow the nose wheel to rotate when flying. My -7a friend has this condition (anti-splat wheel) and it caused a primary vibration of the nose gear in flight due to wheel imbalance. The balance was fixed, but is everyone happy with the wheel always rotating in flight? That seems draggy.
Just asking . . . .
Bill
RV-7
Old 07-07-2022, 09:00 AM
stringbender stringbender is offline
Default vertical vibration
I posted a week ago about having vertical (up and down) vibration on NLG tire, after inspection I found two flat spots. I removed the classic aero tire, put a replacement tire/tube from my hangar mate and flew it. It was worst...but the tire was 1/8'' out of round. I then order two new ones from Spruce, and the tire was true. I then talked to a EAA Mentor who installs a spacer inside the wheel, so to obtain a normal torque on the 3/8'' bolt. Not the 7-10 foot lbs. The "trick is" to make the spacer big enough that the bearings are free to move, roll freely. That is quite a task. I made several spacers and the grease drag on the bearing made it difficult to tell. Too big and the bearing would rotate on the outside spacer (not to be confused with the inside spacer that was manufactured). Too small and you don't get a torque up of the bolt.
The goal I had was to be able to rotate the tire with bearings greased "one full turn".
History; I purchased the aircraft 1 year ago, everything has been fine until a vertical vibration was felt. 80 flight hours and approx 100 landings. I did notice the original spacers had rotated which I think was from the original owners history, it leaves slight grooves in the Yoke.
Suggestions?
Comments?
Question; Does anyone have a internal spacer dimension?
