Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 08-30-2021, 02:40 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Does Andair have a recommended torque value for those screws? All the charts I found specify dry screws.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 08-30-2021, 04:43 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
Ya torque is about that tight. They are small who needs a torque spec.
And I follow the manufacturers spec on sealer.
I will also say I love the 6 port valves I've gotten from them.
Good stuff Art
Old 08-30-2021, 07:40 PM
digidocs's Avatar
digidocs digidocs is offline
The instructions I have specify staking with a punch as an alternative.
Staking took about 5 minutes total and I suspect that you could remove the screws if you really wanted to without damaging the valve.
Old 09-02-2021, 07:32 AM
JDBoston JDBoston is offline
Default Look closely if unfamiliar
One word of caution if you choose to use some sort of "semi-permanent" bonding method for these screws.
I am going to stake them, but I just opened my brand new valve which came with the RV-14 kit. Everything looked fine and it was sealed from the factory. When I started to assemble the fittings with the screws I noticed a few of the screws were different lengths, and also a few of the screws had what looked like either cracks or notches cut into the face of the screws.
I emailed Andair and they confirmed that all of them should be the same length and they should not have any notches. They are now sending me new hardware. I am glad I didn't use Loctite 638 or similar as I would have more of a mess on my hands now. Hopefully my experience was an unusual one, hoping there aren't further quality issues inside the valve.
Jeff
RV-14A
Status: Tail mostly complete, Wings complete(ish), Working on: Fuselage Kit, Finish kit on order (EXP119)
http://vans14a.blogspot.com/
