Go Back   VAF Forums > Model Specific > RV-9/9A
Old 03-25-2021, 09:20 PM
chintangent chintangent is offline
Default Close Quarters Riveting
What's the best tool you recommend for dimpling/riveting tight areas close to spars? I had a pin hole puncture in my trim tab and was advised by Vans to drill to #40, dimple and set a #3 flush rivet. After I drilled the hole and deburred, I realized that I'm too close to the spar web to be able to dimple/rivet. I'm looking to expand my tools anyways. What do you recommend? Unfortunately, it's also somewhat beneath the trim tab horns, so only about 1/4" clearance on top and about 7/8" clearance on the bottom.
ID:	9697  Click image for larger version
ID:	9698  Click image for larger version
ID:	9699  Click image for larger version
ID:	9700  Click image for larger version
Building RV-9A - Empenage Kit 99% complete, wings QB received and started
Old 03-25-2021, 09:29 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Pop rivet dimpler with the female die ground to a “D” shape to get in close to the spar.
If you haven’t ground some dimple dies, well, you will....
Mike W
Venice, FL
N164WM
Old 03-25-2021, 10:35 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default diy
Make your own close quarter dimple dies from mild steel and use a machine countersink to make the depression. The male part of the die is a matching rivet that will be tapped into the hole with a drift punch. The dimple won't be perfect, but it will be good enough in such a location.
The rivet itself can be set with a squeezer or a narrow flush set and thin bucking bar.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 03-27-2021, 11:14 AM
Thanks Paul. Your feedback has been very helpful.
Old 03-27-2021, 11:23 AM
wirejock's Avatar
wirejock wirejock is offline
Default Dimple tool
My first choice for something like that is a Cleveland Vice Grip Dimpler.
Second is the pop rivet dimple tool
Third is a 3/16" gun set. The dies fit in the set. Turn pressure down to about 10 psi and feather the trigger. I also have home made bar that holds the female.
Fourth is a home made close quarter jig as mentioned above
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 03-27-2021, 11:32 AM
bjdecker's Avatar
bjdecker bjdecker is offline
That's a tight spot.
I think I would forgo putting a rivet in there. Use a debur tool to put a little more of an angle on the hole, then mix up some epoxy with milled fibers and fill the hole; push the material into the hole - forming a sort of mushroom plug.
Sand & Paint...
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 03-27-2021, 03:58 PM
gyoung's Avatar
gyoung gyoung is offline
Use an NAS1097-3 rivet. You can countersink with a couple turns of your deburring tool. Set it with a no-hole yoke in a squeezer or a long set in a gun.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project next
4 L-2 projects on deck
Old 03-28-2021, 09:23 AM
Chris Scott Chris Scott is offline
Not to go off-topic, but "close quarters riveting" reminds me of installing a transponder and encoder in my first plane - a 150.
A&P: "I need you to crawl back in the tail cone and buck these rivets."
Me: "OK"
HOLY ****!
Bowling Green, KY. all paid up!
Old 03-29-2021, 08:31 AM
sf3543 sf3543 is offline
I'd use a pop rivet and fill in the hole.
But, if you decide to try riveting a solid rivet, use a soft rivet.
It would be a rivet without the divot in the middle of the rivet head and much easier to squeeze. (AN426A rivets)
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 03-29-2021, 11:05 AM
eric.the.blonde eric.the.blonde is offline
+1
Pop rivet all day. There are a few spots where I wish I had simply used a pop rivet and called it "good enough" instead of trying to be "better" with a solid rivet.
Eric G.
Ann Arbor, MI
RV-9A under construction (wings)
President, EAA Chapter 333 Flying Stinkers
