Old 07-20-2018, 06:00 AM
tswanson tswanson is offline
Default Which Nut Plate Jigs?
I'm looking to get some nut plate jigs and nothing popped up when I searched this topic. Anyone have any recommendations on what size nut plate jigs a person needs to complete an RV-7 QB? I'm still on the empennage, so haven't gotten far enough to understand what nut plates are used where.
Todd Swanson
Tremont, IL
RV-7 Empennage in progress
Old 07-20-2018, 07:39 AM
sf3543 sf3543 is offline
Default You can get by with one
If you get a nutplate jig for a number 6 screw that does both double and single wing nut plates, you won’t need any others for an RV build.
Just start with a #28 drill bit for a number 6 screw, drill the lug holes and then drill out the center hole to the correct size for your screw, since the nutplates have the same wing dimension in most cases.
VANs uses almost all #8 nut plates, except for a few larger ones, but you may want to use smaller #6 screws in some places.
Mini nutplates and larger nut plates, like some 1/4” nut plates, are different but for those few you can use the nit plate itself as the jig. A little slower but there aren’t that many in an RV build.
For an example of this type jig, search on the following;
Nut Plate Jig #6 Single Wing Standard 518G
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder currently flying
RV3B & Legend Cub
Old 07-20-2018, 10:27 AM
rzbill's Avatar
rzbill rzbill is offline
I would agree in concept with Steve. Only difference is that I had one with a #40 pilot instead of a #6 screw pilot. It worked fine. I had plenty of other jigs obtained through an ebay tool purchase. Used them some but the #40 piloted one was my go to. Either one would work I think.
Bill Pendergrass
ME/AE '82 Retired.
RV-7A: Flying since April 15, 2012. 980 hrs
YIO-360-M1B, mags, CS, GRT EX Horizons & A/P, Navworx
Old 07-20-2018, 10:44 AM
tyconnell's Avatar
tyconnell tyconnell is offline
I just purchased the #6 variant one from ACS - it's a #6 which will do both single and double lugs (if that's the right terminology). I'm installing empennage tips with #6 screws.
(moderators: it's OK to link to VAF advertisers, correct?)
Ty Connell
ty.connell@gmail.com
Donated 2021
Old 07-20-2018, 11:31 AM
Gee, I just use another nutplate. Put a screw or a cleco in to hold it, drill one rivet hole. Drop a cleco in there, drill the other. Once in a while, rivet the nutplate to the airframe and use another one as the tool.
Why bother with a special tool?
Dave
Old 07-20-2018, 11:47 AM
Default me too
I just use a nut plate. Take a standard machine screw, put a nut on it, drill the screw hole, thread screw into nut plate a couple of threads, run the nut down to hold it, drill away...
No muss, no fuss, no wrenches required...
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
Old 07-20-2018, 12:03 PM
Wunderon's Avatar
Wunderon Wunderon is offline
As above .., use nutplate itself for a few places, swapping out before the #40 holes get wallowed out by the drill bit. I use a screw ground down to a couple threads to hold it. Flare on screw keeps everything well centered.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 07-20-2018, 01:24 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Get #6 & #8
I used both the #6 & #8 jigs quite a lot while building my QB 7A. I agree that the one's that ones that can do both the 2 lug & single lug nutplates are very handy.
I respect the folks that like to use the nutplate itself a the jig but IMHO it's tons easier using the nutplate jig tool. Do 20 using the jig and 20 using the nutplate and tell me which way you want to do the next 20..
Slightly off topic but when I built my 12, I was amazed to find all 3 nutplate hole prepunched. All you needed to do was final drill and de-burr and you could rivet the nutplate in place. Hardly used the jigs at all while building the 12.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 07-20-2018, 01:41 PM
Walt's Avatar
Walt Walt is online now
The Deutsch guns are the way to go, you could do 20 in the time it takes to do 1 with a nutplate jig
http://www.aircraftspruce.com/catalo...s/nutplate.php
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 07-20-2018, 01:47 PM
NYTOM's Avatar
NYTOM NYTOM is offline
Talking Nut Plate Drilling Jig ?
I built my whole plane using a a nut plate drilling jig called a nut plate. I didn?t even know there was such a thing. Seems llke the holes on the jig would get larger and sloppier the more you used it. Just using the nut plate your going to install seems like the easiest, most accurate way to go. Just make sure you cleco the holes as you go to keep it aligned. Never had any problems this way. Oh no, maybe all of mine are wrong.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP. KJNX
