Old 09-04-2021, 05:37 PM
JTJones's Avatar
JTJones JTJones is offline
Default Another configuration…
If you cut the leg length right and use a pool noodle for cushioning it will roll down and go “over center” and sit in the gap between the floor carpet and panel cover carpet.
ID:	15407  Click image for larger version
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2021 VAF dues paid plus beer money😜
Old 09-15-2021, 11:04 AM
jimkwalton jimkwalton is offline
I'm dense. I need photos of this set up in place.
Originally Posted by tom_AZ View Post
Here's what I use in my -10; I've seen a couple of -14s, but haven't paid enough attention to the cockpit design to know if it will work in that model.
The PVC portion is a minimal modification from what I received from the original builder when I purchased the A/C--thanks John and Teresa. I slip the short PVC segments over the bottoms of the starboard rudder pedals. The "arm" length was trimmed and the angle adjusted to allow a tight fit with a slight "over center"--when the crutch tip is jammed into the junction of the floor and bulkhead beneath the seat, e.g. the arm slopes up slightly in the direction of the rudder pedals. Note that the arm is offset from center so that the stick itself doesn't interfere with placement. The combination of pressure and rubber crutch tip minimizes slippage risk. I can install or remove while sitting in the cockpit. That locks the rudder, and if I'm just refueling, going to breakfast on a calm morning, or similar, that's all I do besides tiedowns.
If it's windy, or if I'm going to be away from the A/C for any significant period of time, I also secure the elevator and ailerons. Basically, one nylon strap passes through the outboard port-side seatbelt (Hooker) buckle, wraps x 2 around the starboard stick and back. That is repeated for the second strap on the opposite sides, creating an "X" pattern. The styrofoam cylinder (as used for physical therapy, and readily available from Amazon, as are the straps) is placed between the starboard stick and front of the seat before the straps are drawn tight. That leaves the elevator in a very slightly up orientation (it could be changed to slightly down by using a cylinder with a larger diameter). I've left the A/C for multiple days at KWJF (Lancaster, CA) on several occasions. Typical winds are in the 25 knot range there, with higher gusts--no issues.
No risk of departing with the locks installed. You couldn't get in and buckle up with the ailerons/elevator secured, and it would be difficult to taxi without noticing that the rudder pedals can't be moved.
Old 09-15-2021, 11:05 AM
Please show me in a photo in place.
Old 09-15-2021, 11:06 AM
Please posts photos of in-place devices. Most of what you all are saying just goes right over my head.
Old 09-16-2021, 04:28 PM
tom_AZ tom_AZ is offline
Default Photos "Installed"
[/ATTACH]
As requested. Good timing--a day later and the seats would have been out in preparation for this year's Condition Inspection. Please excuse the old brake fluid stains. I guess I need to get after those. In one photo, just the rudder lock is installed, and it was installed hastily at that, so te alignment could be better. In the other photo, I installed one of the straps--port seatbelt to starboard stick. To complete the installation, you would connect the starboard seat belt buckle to the port stick with a second strap, and apply a little tension. When installing "for real", I normally loop the belt around the stick an extra time, although I don't know that doing so adds much. Where the elevator rests is a function of foam cylinder diameter and seat position.
Effective? Yes
Simple to build? Yes
Inexpensive? Yes
Lightweight? Yes
Elegant? ...Not so much.
Name:	Rudder Lock_Installed.jpg
ID:	15897  Click image for larger version
Name:	Control Locks_Installed.jpg
RV-10 (purchased flying)
2021 Dues Paid
Old 09-17-2021, 07:11 AM
dmattmul dmattmul is offline
Smile Locks
Although not cheap I found the gust locks from rvplastic parts work very well and quite effective. We've all got a lot of emotional and financial investments in our airframes and I sleep well when traveling knowing these are on.
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully early 2023.
Old 09-24-2021, 06:49 AM
Default Control lock
Originally Posted by cgeyman View Post
I used the pvc for several years but it would sometimes slip off. Feel Alan Nimmo’s device is much more secure and worth the cost.
I bought this. I’ll let you know
Old 10-14-2021, 09:23 AM
Bought the Splat control lock. After adjusting it works great
Old 10-14-2021, 01:02 PM
ronschreck's Avatar
ronschreck ronschreck is online now
Default These work
I used AirGizmos control lock and survived the Sun-N-Fun tornado of 2011. PVC control locks splintered and many others just flipped off the rudder or rudder pedals. These things work well but are grossly overpriced. You can make something similar for a few bucks. Remember your flight controls will likely be subjected to strong gusting winds from every direction, not a steady wind. Imagine grabbing your rudder and slamming in back and forth with a lot of force. Wind does that!
While we are on the subject, consider your tiedowns as well. I saw too many "Claw" tiedowns break during the tornado and the screw-in type pulled out easily. I made a set of tiedowns with three large spikes holding each wing. They held well. You might consider that your tiedown rings are the weak point! Mine didn't fare well in a Kansas windstorm.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2022 Donor
Old 10-14-2021, 03:05 PM
rswalden's Avatar
rswalden rswalden is offline
I agree 100%. Anti-Splat's 3-axis gust lock is ingenious. It is lightweight and locks elevator, ailerons, rudder. I'm NOT a fan of any kind of EXTERIOR flight control gust lock.... for obvious reasons.
Bob Walden (Waldo), CFII-ASMEL, Commercial Glider
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 1000+ Hours
EAA/AOPA/Vans Air Force 2021 Supporter
