  #11
Old 08-30-2021, 11:43 AM
KiloWhiskey1's Avatar
KiloWhiskey1 KiloWhiskey1 is offline
Default Parts source for rebuild
I just replaced my PP alt on my 10. I’d like to rebuild the old one to have as a backup. Does anyone have a source and parts number for a rebuild kit?
Thanks!
Keith Ward
Current: RV-10 N253RV, RV-3 N235RV, Panther build progress
Sold: RV-7 N818PA, RV-7 N818KW, RV-8 N626JL, Christen Eagle II N56RJ
Old 08-30-2021, 12:38 PM
jimkwalton jimkwalton is offline
Default How?
Originally Posted by BillL View Post
Be sure to register the failure with Vans, we want them to have first hand knowledge of failures. Then, contact Hartzell for a warranty replacement. They need to feel the pain. No pain-no-change.
How do I "register" with Vans?
text 214-695-0345
jimkwalton2014@gmail.com
Old 08-30-2021, 05:15 PM
n982sx n982sx is offline
My PP went out at about 300 hours. Replaced and installed a blast tube.
I talked to Hartzell about my experience at Oshkosh this summer and they confirmed that they will not rebuild a PP alternator. Replace at full price is only option unless still under warranty.
They did say that they have talked with Van's many times and have asked Van's to add a blast tube installation in their plans. To their knowledge Van's has not done this and said any installation without a blast tube will likely fail as the heat build up in the tight cowling installation will cause a failure.
150 hours since the blast tube installation on my new PP alternator and so far so good. We will see.
I have 450 hours on my B&C alternator mounted on the vacuum pump pad. I installed it with a blast tube per the B&C documentation.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 08-30-2021, 06:14 PM
Jetmart's Avatar
Jetmart Jetmart is offline
Can you post some pics of your blast tube set ups?
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694
First Flight - June 22, 2021
2021 Dues Paid
Old 08-30-2021, 06:19 PM
BillL BillL is offline
My (Hartzell/PP) documentation for the PP EI60 alternator states the blast tube is NOT necessary.
Bill
RV-7
Old 08-31-2021, 11:34 AM
Just reporting what he told me. Not sure if he meant the issue was specific to Van's cowling installations.
Also checked my PP documentation for both the old and the new alternator. Neither mentions a blast tube but neither one says it's unnecessary. Also checked the current PP documentation on line at Hartzell. It's the same as what I received.
Bob Meyers
Old 08-31-2021, 03:57 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default From the installation docs...
The installation doc's for the AL12-EI60/C (or B), part #99-9900B & C revision F calls for a 1" blast tube, see page 2.
Document available here:
https://planepower.aero/aircraft-alt...-instructions/
Also, there is a specific blast tube adapter part available for the 70A variant (AL12-70), part # 10-3051.
Name:	Screen Shot 2021-08-31 at 3.56.16 PM.jpg
Brian Decker
RV-7 (Flying)
