Old 10-02-2014, 08:48 PM
N941WR's Avatar
N941WR N941WR is offline
Default Draining oil bottles: BOB system
Have any of you tried using one of these B.O.B. collectors before discarding your oil bottles?
Are they worth the money or just another Ginzu knife?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-02-2014, 08:59 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
I've had this for many years and I LOVE IT!!!! Rather than leave each bottle in the filler neck to get the very last drop, I'll drain the bottle then put the bottle into BOB. Depending on how long you leave the bottle emptying into the engine, you'll get a full 1-quart recovery from BOB in anywhere from 12-16 'empties'.
I had always hated throwing away the bottles after seeing how much oil 'pooled' into the bottom after sitting on the floor a couple of minutes after each oil change. Now I'm doing my share in going 'green' with my oil bottles Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 10-02-2014, 09:34 PM
RV6_flyer's Avatar
I have seen Rosie's setup and have wanted to buy one after seeing it. I ordered mine from Amazon. ($13.74)
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-02-2014, 09:41 PM
BillL BillL is offline
Paul, is the collection path protected from dust etc so the collected oil is clean?
I really like the idea, I usually cut the top out of two bottles and use it to collect the drippings by holding them upside down. I sit the "empties" on the hot (car) engine for a while to allow them to drain down, There is a LOT of oil that can remain there, but having a dirty trough collecting dust between changes makes it dark green. (ok, bad joke) Er - - less attractive.
From Rosie: I live in the desert with lots of wind and dust and have never had a problem with dirt in the narrow trough.
Bill
RV-7
Old 10-02-2014, 09:52 PM
Mel's Avatar
Mel Mel is offline
My procedure is; after I pour each bottle into the engine, I set the "empty" down on the wing on it's edge, spout down.
After pouring the last bottle, I go back to the first bottle and empty them again in sequence.
I use the same procedure with my cars.
Not quite as thorough as Rosie's method, but I get most of it.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-03-2014, 06:39 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
I saw one in Iowa once that was shaped like an upside down Menorah. It didn't need the elaborate support or take up as much space. I think it held just 3 upside down bottles but that's plenty. I wish I had bought one. Has anyone else come across that style?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 10-03-2014, 08:38 AM
GLPalinkas's Avatar
Turbo posted a similar idea with just a funnel into a used bottle and another used bottle turned upside down. It's a single shot idea but has worked for me for 3 years. I change out the "empty" bottles eveytime I get to the hangar. Works really well in out Florida heat.
No waiting for the bottle to empty into the engine.
The multi load gizmo looks like a good idea though....
Venice, Fl
Old 10-03-2014, 09:05 AM
wirejock's Avatar
wirejock wirejock is offline
Default Oil
I took one of those large automotive oil containers and use it for collection. It also serves as my oil funnel holder so any drips go into the container and there is very little exposed surface area to collect debris. If I change oil, the containers are set aside with lids. When I'm in the shop, I turn one over in the funnel. Next day, I swap and recycle the old one. In a few days, they are all gone. My Lucy isn't flying yet so this is all automotive but should work fine for airplane as well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 10-06-2014, 10:24 PM
turbo's Avatar
turbo turbo is offline
A simple away from home drip system. a two at a time system or more.
TURBO YES =VAF= Payed Jan2021
Ed D'Arcy
RV6-A 5,300+ hrs, R-44 1,600 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
Old 10-06-2014, 11:40 PM
wirejock's Avatar
Default Drain system
That's a good one too.
Larry Larson
Estes Park, CO
Disclaimer
