I thought mine was smooth....until after I had it dynamically balanced ....... oohhh what a difference.
Heard the best explaination from the Jim Jeffries that did it.....It's like buying a new set of tires and not balancing them. Anytime you marry a prop to an engine, it should be done...... And he's right.
He took it from a 0.5 to a 0.025 - check out the graph.
