Anybody know the recommended fuse size for the panel powered Zulu headset? thanks, JB 819WB
jcbarker Well Known Member Jul 3, 2009 #1 Anybody know the recommended fuse size for the panel powered Zulu headset? thanks, JB 819WB
Pat Hatch Well Known Member Advertiser Jul 3, 2009 #2 jcbarker said: Anybody know the recommended fuse size for the panel powered Zulu headset? Click to expand... 1/4 amp fuse or 1/2 amp breaker.
jcbarker Well Known Member Jul 3, 2009 #3 Thanks Pat. I'm using ATC type fuses. I've not been able to find any with values less than 1 amp.
Pat Hatch Well Known Member Advertiser Jul 3, 2009 #4 Correct, I meant to tell you that I use a 1 amp fuse on mine with an AWG 22 wire. I think that will be fine considering the primary consideration is to protect the wire, not necessarily the headset.
