JurgenRoeland
I decided to follow the advice of many builders to go the Checkoway method for attaching the z brackets. I know this is not the vans manual way but didn't like the idea of elongating the holes
As described in his method on many sites, when making the first holes in the Z brackets for the AN3 bolts, I made a center line on the outside flange (outer side that leans on the spar) and made an offset of 1/16" towards the web.
When matching the tank baffle in a preliminary attempt to mate it, I see that on the other side, the holes for the pop rivets will be pretty close to the edge of the z bracket and are below minimal edge distance.
I only have like .220 to .230 of edge distance from center of hole to edge for the pop rivets to go.
Is this still ok for strength ? or would you guys replace the brackets and go the normal centered way ?
Have any of you drilled the same way with the offset and had a different result on edge distance ?
Just wondering what I'm doing wrong.
![wing-tanks-2-5.jpg](/proxy.php?image=http%3A%2F%2Fjurgenroeland.brinkster.net%2Fjoomla%2Fimages%2Fwing%2Fwing-tanks-2-5.jpg&hash=49b9921268860f7e446651cd8fc2cf24)
