StaringSkyward
Member
I am at the stage of riveting together the wing skeleton and I screwed up around 15 rivets on the main spar to rib joints across both wings on my slow build RV-9. They were all sorts of broken -bent over, elongated, ovalled, figure of eight and a good few were cracked diagonally down the shank but no smilies!
So, just when I thought I'd got the hang of this riveting lark having done all of it solo so far with no big issues, I was downhearted to say the least. I called in the cavalry in the shape of my LAA inspector (in the UK he signs off on your build, so he's your main go-to guy). We looked at the rivet length called out in the plans, which was a little on the long side of perfect but far from being an issue.
Then he asked what I'd used to drive them and bingo! I had used a double offset set because I didn't want to mark the ribs or bend them out of the way to use a straight set. We drilled them out (about 15 of them!) and using a straight set riveted in the replacements -all perfect first time. I've done some more solo since then and they too came out great.
I'm not saying a double offset set is a bad thing, just documenting my experience here in case someone else is stood looking at the same crappy rivets wondering what they've done wrong. As my inspector said: "I only use an offset set if I absolutely have to and try not to do it single-handed". When I build my next RV I'll get a longer straight set![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hope this helps someone.
Matt.
Slow build RV-9 wings
South Yorkshire, UK.
Matt.
