Just to put the thought to rest, yes, I've searched...
So, any thoughts on what the baffle ramp to cowl inlet clearance should be, looking in plan (vertically downward) view? The photo shows the dimension in question. The plans don't show a number but imply that it's small (zero?) Right now that's about how I've cut the ramps. I did set the clearance per plans for the seal fabric, impossible to see in my photo.
I can get the lower cowl on past the ramps just fine, but I'm concerned about tearing up baffles/seals/cowl if things are too close. I have no practical experience to draw on so advice is gratefully accepted.
Thanks!
Thanks!
![916505597_8mhUH-L.jpg](/proxy.php?image=http%3A%2F%2Fwww.abarinnowhere.com%2Fphotos%2F916505597_8mhUH-L.jpg&hash=5b505c213d52190c1e9c1b851057ca29)
