Hi folks. Need some advice (again). I was lucky enough to get a used WX 10 Stormscope and was wondering where you guys have mounted the antenna on an RV6A. I know they are noise sensitive.
(Thanks for the WX 10 Stu)
I used what is called a "skin mapper". Basically an antenna hooked up to a box with 30' cord - has light and sound going off simulating a strike. You start engine then turn on electrical items one at a time looking for the quietest spot on the belly.
