cdmiller
I have a WW 200 RV propeller installed on an RV-8 with an IO-360 M1 engine. My propeller started leaking small quantities of oil or grease, which show up as small streaks on my windscreen. The prop was perfectly dry for the first 108 hours and then started leaking a small quantity. At 130 + hours, the leaking has become a bit worse. I think that the grease is coming from the propeller hub because the grease shows up on the part of the spinner directly behind the propeller blade, on one side only.
Have any of you had similar problems? What can I do to fix the problem?
Any suggestions appreciated.
Dan Miller
RV-8 N3TU 132 hours
Dan Miller
RV-8 N3TU 132 hours
