WTB 5/8 Tube Bender
664781
Looking for a source to buy a 5/8 Tube bender. Not having any luck with with the normal places.. Any ideas?????
Lowe's aviation department
If you're doing gentle bends try a spring type bender. They're available in the plumbing department at Loews and probably Home Depot and Menards too. Here's a picture of a 3/8" one that I used when modifying my fuel system recently. They come in packs of 4 and I think the biggest one was for 5/8" tubing.
My lever-type from Harbor freight worked fine. Cost about $3.00. At the same time, I just as often used the spring type above from Home Depot when I was making shallow bends. In either case, plan on going through a lot of extra tubing until you get the hang of bending it. good luck.
