CharlieWaffles
Wow, you know I've been reading about how difficult the doors, pins and latches are on these RV10s and was I under-prepared! This has been the first time in the entire build I've quite a work session early because the build was fustrating and unprogressive. One day was just fitting plastic door pin guides and after market metal door frame guide (a single one). And that was a 7 hour day.
Luckily, after a brake I formulated a new approach and did some more research. There are so many moving pieces and angles that its not hard to see now why this is a challenge. Tweaking a door plastic guide changes the geometry of the pins going in the frame, etc... I finally found some great hints on VAF and after an entire month, I can say I have ONE door latching system working.
Here are some of the hints I gleaned (mostly already on VAF in other forms)
1) The door pin blocks need to be very close 1/8" to the door jam blocks. This will keep the door from moving forward and aft as the pins are latched.
2) Make sure your placement of these blocks is set BEFORE drilling your door frame holes. Changing the blocks or their location will distort the pin travel. I originally built with the Van's door blocks but changed to the PlaneAround ones as I was using the 180 kit. Better approach would be to use the Vans ones for the initial drilling to the DOOR, but change to the PlaneAround ASAP.
3) Test fit the door jam blocks (any of them) to make sure the distance from the inner door shell to the pin hole is correct. I found I needed to sand a 1/32" off of my door jam blocks so that it wouldnt distort the door as it was closed or cause a massive amount of friction.
4) The door frame blocks (using metal PlaneAround) can be very fickle on their placement. I found that the best way to get the best geometry after drill them was to go 1 size large for the bolt holes. Leave the bolts loose and actuated the latch. The pins will insert and put the blocks in the correct position. You will need to use some pliers and a wrench to tighten the bolt to keep the location or it will move when the door is re-opened.
5) A very small amount of grease in the door jam blocks will greatly ease the required pressure to actuated the handle. I went from "just ok" with the resistence to "very happy".
6) The C-1006C Handle Pivot block of the gear mechanism is very hard to assemble in the door pocket. I mistakenly shaved the inner dimension to make the racket arms and gear fit more easily, but now there is too much slop. This will have to be replaced when the door comes off.
7) The same piece (C-1006C) appears to be MARGINALLY too tall for the pocket. If you look, it's squared off back side is being pushed up slightly by the radius of the fiberglass pocket. I think this is causing the distortion and friction that some people report when the screws are tightened. I suspect radiusing this back side will work pretty well.
Oh, did I say I hate these doors?????
