If you live in the NW and have a working ICOM 200 radio that you would be willing to let my use briefly, I would appreciate it very much. I would be happy to fly to your field - my ICOM works a little bit. I would just like to take mine out of the tray and install a known good one to learn what the current background noise signature of my -6A is.
It appears that in addition to potential wiring problems the ICOM 200 in my RV-6A may have a weak audio amp. Recently, I corrected mag wiring in an attempt to address EMI from the ignition system but don't know if I will be able to confirm an improvement with the existing radio.
Thank you in advance if you can help.
LarryT
LarryT
