Scott Will
OK... I want to look forward and focus on a solution...
Due to physical limitations I had to fit my wings with the gear on. It's a nosedragger so the main gear weldments attach to the front of the spar. Ya'll know that.
Anyway, I have two ground down bolts in each of the top two holes (both sides). I had to put a bolt in the lower hole to get the correct dihedral... unfortunately it was a scrap NAs 1307 bolt. I drove one in all but 1" and the other side all but 2".
I have to get the wings off in order to do all the nutplates on the bottom. How do I remove the lower bolts with the main gear leg in the way?! Has this ever been done?? I need some sort of way to drive them out but no access from the front side. Any help??? please?????
I know I should have used hardware store bolts and all that...
Thanks for your suggestions for a fix. I'm sure someone might have run into this in the past.
- Scott
- Scott
