Skyflies- Google maps says we're about 2 minutes away from each other. It would be great to have a "building buddy" so close!
As far as piloting, I got my Private ticket in 2002 (47 hours). My logbook has 128 or so hrs, but unfortunately I'm not current at the moment. I've flown in and out of KPWK, KMDW, 06C, Galt, DuPage, Dekalb, Hinckley (love the grass strip!), Madison and Janesville Wi, Champaign IL, Winona MN, and quite a few others. I used to like going out to Whiteside IL and then up to Janesville for lunch.
At this point, all available resources are going into the -7A build and stuff for the new house, so it looks like I'm grounded for a while!
UPDATE: Compressor is installe and plumbed, tool are purchased, empennage kit has to wait until September
We've all seen this compressor before, the Kobalt 30-gallon unit. Looks good in black! Still a noisy machine, but nothing like the oil-less units. Takes about 4 minutes to bring the tank up to 150 PSI from zero; this'll improve slightly as she breaks in. For now, I'm running 110v... 220 to be installed soon. I've been studying, and feel pretty confident that I'll be able to do it myself with out a problem. Just in case, my electrician buddy might supervise!
You can see my shop plumbing here-
I've turned 1 50' length of tubing into 2x 25' lengths, and used 1 as a semi-permanent shop line. Two coilies coming off that feed, with an additional regulator to turn shop pressure (90 psi) into Rivet pressure (approx 40 psi, or whatever I need). I can disconnect this from the feeder hose, and use the other 25' length as a floor-hose.
This marks a major milestone, as my shop is now 95% complete, and actual building is in the (very) near future. To get to this stage is seriously exciting, and I can't wait to get started! Unfortunately, finances dictate that I have to be paient for a couple months, ha-ha
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
