fat cats
Having now actually built a light plane... I can tell you my only "trick" was to _NOT_ do. I didn't put on an IO-360 with a heavy aluminum CS prop, I didn't install a 60amp alternator, I didn't install a full steam gauge panel, I didn't install 50lbs of radios and auto-pilot.
IO-320, Sturba wood climb prop (much more fun), 7Amp B&C Vacuum pad alternator (2lbs installed), LED nav lights, Dynon DA-10, EIC engine monitor. I don't like the EIS, I'd go all Dynon today. Maybe D180.
I do plan to fill the rivets in the wing with Super Fill, that would weigh under 1 lb for all ten-thousand whatever heads on the top of the wing/fuse and increase speed and appeal. I plan to do a very thin coat of paint, plain off-white nothing fancy, just enough to cover my oops'. My ship will never turn heads at OSH, other than being a fastback, it would blend right into the woodwork.
It doesn't look too bad from 100' with the setting sun hitting it!
-Bruce
