Yep, I put the screw though one side of the grip and only one side of the stick. The stick is thin, but the threads I tapped are holding up fine after 190hrs. Think the dab of RTV also helps prevent rotation, so not that much stress on the srcew. And as Mel pointed out I off-set the grip a little to the left, as I'm right handed, So with my arm resting on my leg the grip angle is natural.
