macrafic
I've looke at several wiring runs with pictures on this forum, but am confused.
If installing conduit, it can't be run anywhere outside of the 2 outermost baggage floor ribs, because the external steps do not leave enough room to run the conduit under or over the step.
That leaves one "rib bay" on either side, right next to the center tunnel. The outer portion of that bay has the screws/nuts holding the external step block in place, so the conduit would have to be run under it (doable). The inner portion of that bay would require drilling another 3/4" hole in the bulkhead, right next to 3 other holes that are already there (the elevator pushrod hole, the manual trim cable hole and another wiring hole). My feeling is that this would have a tendency to weaken the bulkhead.
What am I missing from the other installations I've seen here? Appreciate your comments.
