Bob Brown
I'm running wiring hither and yon in my RV-10, called Van's Tech Support line today to ask whether or not I could drill another hole to install a snap bushing (like maybe 5/8" or 3/4" through the F-1004C&D Center Section Bulkheads...the answer? "Well, drill them if you want, we don't have any test data on that, so you're on your own". Perfect, thanks a bunch for that.
So has everyone managed to fit all wiring through the 4 holes provided in the tops of the F-1004C&D's or have you put in more holes for snap bushings? I recognize this is a central structural point, but I also realize that most of these thick (.063") pieces of channel would probably be just as strong with another 5/8" hole drilled in the center of the 2" wide channel.
What say the experts??
