humptybump
Warning: this is a gorpy detailed post
For the purposes and this set of questions, I'm a only discussing the GPS capabilities. COMM/NAV are not a problem.
With a GNS4xxW The wiring has:
Additionally, there was:
There was also:
Thus far I've figured out some of what changes when the GNS4xxW is replaced with a GTN6xx (but obviously not everything). The only GTN install manual I could find is Rev.4 and the G3x install manual Rev.R
I have found:
I don't find any ARINC connection between the GTN and the GTX23. Is this connection needed for the GNS4xxW but not needed for the GTN6xx?
What was the purpose of the GSN4xxW ANNUNCIATE connection to he GTX23 and which is the corresponding connection for the GTN6xx?
The GNS400W does not have an audio alert out but the GTN6xx does. What audio notifications are generated by the GTN6xx that are not also generated by the other components?
Thanks in advance for those who have forged this path before me!
GNS4xxW RS232 IN/OUT to the GDU460 (G3X Touch display)
GNS4xxW RS232 OUT serial to the GTX23 (transponder)
GNS4xxW ARINC IN/OUT to the GAD29 (ARINC module)
GNS4xxW ARINC IN from the GTX23
There was also:
ANNUNCIATE / TIS SELECT between the GNS4xxW and the GTX23
I have found:
GTN to GTX23 RS232 interconnections on "G3X-Rev.R pg 21-13"
GTN to GAD29 ARINC interconnections on "G3X-Rev.R pg 21-16"
