Pilottonny
I am currently wiring up my radio and audio connections and am confronted with the following signals to be wired to the intercom:
- SL30 com. ? OK no problem, the manual is pretty clear, how to connect up.
- SL30 nav ? not sure, if there is a way of internally getting the signal to the com side? Need to check the manual on this. If not, I need to wire it to a switch to toggle between Nav/Com, should not be a problem.
- Dynon Voice alerts ? Problem 1: This is just one wire from the HS34? if I use the Dynon ground, for the second wire, I may have a problem with ground loops? I need to swap the single wire for a shielded wire also.
Problem 2: where do I wire it to? If I wire it to the music input, I will no longer be able to use that input for an Ipod or CD-player, right? The second music input on the PM-1000 II can only be heard by the passengers not by the Pilot and co-pilot!?
- GTX328 Transponder ? There is a few voice alerts from the transponder also. Where do I wire the transponder Audio to? Parallel to the Dynon? I am not to worried about this, I could live without these voice alerts and make things simpler, anyway.
As always, many thanks in advance for your input. Tonny.
