I had the same problem and fabricated my own shield. I also ground a bit (1/16-3/32) off the lower bracket edge for more clearance. You could rivet a doubler to the bracket channel in the relived area if you are concerned about bending strength.
I am also trying to figure out how to route two more RG400 cables for a Nav/Loc antenna in the tail and a Comm 2 antenna. I thought there was a rumor of some new nylon tunnel hold downs with a larger cable opening. I put the ADS-B on the aft side of the read bulkhead, so that eliminated a fourth RG400 in the tunnel. I also added a second cable bracket over the rudder pedal assy for the extra wires.This is a 100% custom wiring job with a few more cables that the standard RV12 avionics kit.
John Salak
#120116
Skyview System, GTR200, IFD540, AP, ADS-B, PM3000, ACK E-04
