Depending on where the wiring goes and whether you have a center console, you can use the center tunnel (and it is ok to put a grommet on the other side of the web from the manual trim location), you can pass into the spar bulkhead above the spar at the side skin (can be a little messy and visible if you go just above the seat pans) or under the armrest rib or under the side rails. Once in the spar bulkhead you can go vertically to under one of the forward stiffeners or the forward side rail/panel support (for a tipup; I'm not sure of the structure for a slider). In my -6A I routed the headset wires down the left side rail to the seat brace, the antennae down the right side clear of all other wiring and passing through just below the seat pan, the lighting down the rail on the right, and most other wiring (AP, flap, PTT, etc.) down the center console, through the spar web and into the elevator pushrod tunnel. The big consideration was to keep the antenna cables clear of wires carrying current.
