wire kit
I included it in my FWF kit. There are a lot of things you won't need or use, but many things that are used. The wires are already marked, in some cases, for what they are used for. The schematic is helpful. You may or may not need to add other items. Matter of preferrence or choice. For a basic plane, it will be adequate. If you are adding a lot of extra systems or electronics, you will need to supplement extra wire and switches and breakers. But overall, it is a good start and a good value. All the wire is AC grade.
Roberta
