Is there any reason not to locate wire bundles on the aft side of the sub panel in an RV-6 slider? I am in the process of replacing avionics and wiring, and much of the old wiring is on the forward side of the sub panel (between sub panel and fire wall), making it difficult to access and work with. I want to move most of the wires to the aft side of the sub panel, and there is plenty of room to do so. It seems inefficient to have the wire bundles back there anyway because many of the leads off of the bundle are routed back around to the aft side of the sub panel anyway to attach to the terminal block. (Ground attachments are all over the **** place.)
Hope this is not too rambling of a question.
