SX-ALY
Active Member
Hi
I'm posting that for a guy that i met at work place and owns (bought) an RV-7A. He is not member of any forums (i guess not an internet guy) and not a builder.
We talk a little about RVs and I told him that i 'm searching a lot in forums and builders sites and he ask me to post few questions here about his problem.
He experienced cold CHT (~250) and Oil temperatures (~165)now in that cold weather and he was thinking to reduce the cowl air inlets by placing an aluminum plate with smaller hole on it, so to reduce air coming into the cowl thus less cooling.
I didn't like the idea screwing aluminum plates in front of the cowl but he said he already tried that and he reduced the inlet size (by trying and error) by 50%!!
Results were good. He raises CHT to about 350 and oil to about 185+ in cruise which is pretty good for what i red here.
The problem he faces was that he lost Cabin Heat !! Obviously he got the cabin heat air input in the cowl air inlet so by reducing air flow there he reduces-eliminates cabin heat.
So to summarize the questions:
1. Are CHT temps at 200 -250F normal or too cold? Few posts i found the say over 200 is OK.
2. Blocking oil cooler only by Aluminum tape , shutter, etc or there is an oil temperature thermostat that he can use to raise the oil temps like that http://www.perma-cool.com/Catalog/Cat_page14.html
Anybody had success use that or something similar?
3. I found few post that builders block the cowl outlet like in this thread
http://www.vansairforce.com/community/showthread.php?t=12382&highlight=winter+inlet
What the advantage/disadvantage to do that at cowl inlet (i 'm guessing increase drag as one, besides reducing cabin heat in his configuration)
Also many uses Duct tape to reduces cowl inlet. How you apply it? How many layers, is it safe? Any pics, description?
Any other ways of doing that?
Thanks in advance
If there is any questions like type of oil cooler, etc i will pass them to him so i can have the answer.
I haven't seen the plane by myself.
Thanks in advance
