For those that haven't followed my posts, I purchased a partially completed RV-6A and am progressively fixing a variety of errors.
Today I shortened the small aileron pushrod to get the bellcrank in the correct neutral position. I then used the tooling holes to get the aileron neutral. I then put the wing tips back on (rigged by previous owner) and sure enough, he used the incorrect neutral position (carried his mistake from the bellcrank I think) to set the wing tips. The trailing edge tip is ~1/4" low and needs to be fixed.
I spoke to the guy at Avery to get a dimple die for this and he had a good idea. He suggested slicing the trailing edge and re-positioning to alignment and glassing it in this shape (need to remove the rib first).
The other option would be to drill out all of the nut plates and bond an .032 alum strip to the back side of the edge. I could then re-drill each of the holes and add new nut plates. This option seems a bit easier (not much) and would avoid having the trailing edge of the wing tip drift off the neutral line. However, I am afraid the epoxy bond may not be strong enough to support drilling holes from the opposite side.
I thought others may have gone through this exercise and have ideas for fixing it.
Thanks for your assistance.
Larry
Larry
