Brian - although the workmanship may not be the best, everything looks correct. Blind rivets where used in the inboard spar web area as this area is actually two webs separated by hidden spacer, or block that is sandwiched in. you can look through the leading edge and verify that those blocks are indeed in place as the rivet heads are visible from the front. You want to make sure none of the rib flanges where drilled into those spacer blocks as they are hidden from the back side of the spar.
The extra holes look to be a layout error, easy to do on the 6 wing as nothing was predrilled except later model skins. I would not consider them an issue, again, as long as they where not drilled into the spacer blocks.
The blind riveting was not done well, but I would not fret over it. Double check to insure the angle attached to the rib is bolted to the spar per plans. The angle is riveted as you can see to the rib. Some of those rivets where drilled into the lightning hole flange, not good practice, but not a deal breaker in my opinion.
The spar cap shop heads look good.
The 6 wing was very overbuilt. There is some school of thought that the factory derated the wing spec (g's) allowing for some build error or variance.
Personally, as long as the hidden spacer blocks where not drilled into, the rib angles are properly drilled to the spar and bolted per plans, I would fly that wing.
