Well, getting set to finish off some of our right wing(left is complete) and after riveting on the leading edge assembly we've noticed in the third bay from the outboard end of the skin has a slight oil-canning depression![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
When we had this all clecoed together nothing was showing any sort of a problem. We pulled all the AN rivets from the affected bay out to the inboard end of the leading edge assembly and everything was flat.... Hmmmm. So we went back and started where we took some out and the same thing happened once we got 20 or so rivets back in.
Has anyone had this happen at all? Sure hate to pull all the AN top skin rivets to spar and the remaining bottom to see it come back. I would do it if I knew I could get that out.
