BGS
Have a new flying RV10 that was a QB kit. Noticed that when flying at cruise and the autopilot is flying, the autopilot automatically centers the ball by adjusting the rudder trim. However, when the ball is centered, the right wing is a bit lower than the left. If you trim so the wings are level, the ball is about a 1/4 off of center to the left.
I checked that the ball is centered when the aircraft is on the ground and level.
Also when flying, the ailerons are both very slightly lower than trail.
Looking for ideas on where else to check that would be causing the problem.
Appreciate any input.
Brian
Brian
