I'm fabricating my own splice strips that go between the leading edges and the fuel tanks. Got my tanks from a guy pre-built but didn't get the strip, part W-1019.
I need some measurements. First, how wide? My guess is it should be 1.5"
Second, how far from the edge to the outboard screw holes, then inboard edge to the rivet holes. Looking for accurate numbers, like within 1/32 if you can.
Bonus points if you can get me the distance from the ends of the strip to the aft edge of the leading edge skin once its installed. Should be like 1".
Thanks in advance!
Thanks in advance!
