lucaperazzolli
Hi,
I need some experienced words about my organization of the construction sequence because I need to shorten times (an A&P will help me to install the engine but he's not longer available)
I've just finished my wings and all the options (vent&fuel line, fairing, flaps etc.)
I need to go into the engine mounting process (I jump the canopy for hot days) so I need my baby on wheels.
I'll turn my fuse upside down and I install the gear (previously drilled), the axle too and the wheels.
The manual give me this sequence :
- main gears axles and brake assembly
- brake lines
- gear leg fairings
- main wheels fairings
Q: can I install the wheels, put the fuse upside on them and install the engine. Later I'll do the wheels alignment and gear leg fairings.
Advices wellcome
Thanx in advance
- brake lines
- gear leg fairings
Advices wellcome
Thanx in advance
