flywithme623
Active Member
I have come to a point everyone warned me about but I am sure, like for most problems, there are solutions!
I am building an older stile Fuselage kit (not pre-punched). I am aware that I am out of sequence because I have not build the wings yet.
I have come to the point to measure the distance between the main and rear wing-spars so I can drill and rivet the F-815 seat-rib to the F-804 bulkhead.
DWG 25 is calling out for an approx. 26 1/2 measurement.
So now I am wondering: since I will not have wings of the same building period and most likely end up getting a new slow or QB kit, what are the dimensions on those new pre-punched wings.
Now I hope to collecting some data to find out how accurate the outcome of your builds are and to help me in the decision making how to proceed in this problem solving process.
If you have a post 2005 kit that has pre-punched wings, can you provide me with the measurements of both sides of your wing spar?
What I have seen so far, in regards to the Empannage I have build, the pre-punch technology is very accurate and I can see tolerances of 32ed's of an inch and possibly even better.
If that is holding true for the new technology wings I would not see a problem to get a dimension between the main and rear wing-spars from you that I can use to set the rivets to the above mentioned location.
If I find that you are all over the place with the different wings Then I really have a problem
but like I said, there is a solution for that too ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Guess I have to build some wings!!!
Thanks for your input.
